luisgo98
Feb 18, 2017Aspirant
Netgear A6200 Windows 10 - 5 GHZ problems
I have problems with my adapter finding the 5 GHZ signal from my AT&T router. Sometimes it does, sometimes it doesn't. I have tried going into Device Manager, Netgear A6200 Properties, Advanced........
JamesGL
Mar 16, 2017NETGEAR Employee Retired
Hi luisgo98,
Try to uninstall the adapter. Reinstall it using the standalone driver.
luisgo98
Mar 17, 2017Aspirant
Hi James,
I first uninstalled Netgear Genie from my computer (maybe I shouldn't have?)
Then I downloaded the new driver using the link you provided and installed the one that said "standalone".
Now I don't know how to activate or access my network using the A6200, since I no longer have the Genie to activate it.
The A6200 just has a blinking blue light but no access to 5GHZ.
What did I do wrong and how can I correct it?
I am not very computer savvy so please provide detailed instructions.
Thanks for all your help.
- luisgo98Mar 17, 2017Aspirant
I also downloaded the Netgear Genie Version 2.4.38.
Still no access to the 5GHZ band.
- realdead_manMar 18, 2017Apprentice
Tired of waiting for updates that don't work anyway.
I think TEN (10) MONTHS was a reasonable time to wait for a fix, RIGHT?
Never AGAIN will I BUY NETGEAR.
I purchased an ASUS USB AC53 nano.
(realtek chipset)
WORKS PERFECTLY, all windows versions, all modes!
$40USD
- updatedriversMar 18, 2017Aspirant
I've been having this nightmare for the past few days. Finally was able to get a fix. My drivers for the A6210 are the 0.35 Netgear standalone drivers. I have confirmed my 5ghz connection is working on Windows 10 Pro 64bit with no dropping.
I managed to get this working by going to: https://www.slimwareutilities.com/slimdrivers.php and installing SlimDrivers free. After installing and running a scan, it seemed my drivers for Intel(R) 9 Series Chipset Family SMBus Host Controller - 8ACA2 and Intel(R) Management Engine Interface needed to be updated.
Here are a few other details for the NETGEAR driver installed.
SSID: -
Protocol: 802.11n
Security type: WPA2-Personal
Network band: 5 GHz
Network channel: 149
IPv6 address: -
IPv4 address: -
Manufacturer: NETGEAR Inc.
Description: 802.11ac Wireless LAN Card
Driver version: 5.1.22.0
Driver Provider: NETGEAR
Driver Date: 4/21/2015
Driver Version: 5.1.22.0
Digital Signer: Microsoft Windows Hardware Compatibility Publisher
Driver Details:
Driver Files:
C:\WINDOWS\system32\DRIVERS\A6210.sys
Provider: MediaTek Inc.
File version: 5.01.22.0000
Copyright: MediaTek Inc. (C)2015. All rights reserved.
C:\WINDOWS\system32\DRIVERS\FW_7662.bin
Provider: Unknown
File version: Unknown
Copyright: Unknown
C:\WINDOWS\system32\DRIVERS\Patch_7662.bin
Provider: Unknown
Copyright: Unknown
C:\WINDOWS\System32\drivers\vwifibus.sys
Provider: Microsoft Corporation
File version: 10.0.14393.0 (rs1_release.160715-1616)
Copyright: © Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32\RaCoInst.dat
Provider: Unknown
Copyright: Unknown
C:\WINDOWS\system32\RaCoInstx.dll
Provider: Mediatek Inc.
File version: 1.0.12.3
Copyright: Copyright(c) 2014, Mediatek Inc. All rights
