Kasperczak
Feb 22, 2019Tutor
Netgear A6210 - limited access on Windows 7
I recently acquired the A6210 High Gain USB adapter. I have successfully got it to work on Windows 10 as it was automatically recognized. However, on Windows 7 I had to install the Netgear driver and...
Blanca_O
Feb 24, 2019NETGEAR Employee Retired
Hi Kasperczak
Welcome to NETGEAR Community!
Please try to set static IP address. Go to Network and Sharing center > Change Adapter settings > Right-click Wireless adapter > Properties > Double-Click IPv4 address > Select Use the following address > input IP address and Gateway in range to your router.
Blanca
Community Team
Kasperczak
Feb 25, 2019Tutor
I tried setting a static IP address (which was a good idea) as suggested, but it didn't help. The connection "Wireless Network Connection 4" still says 'Unidentified network' and I am unable to ping anything except the loopback and the host IP that I assigned. I also tried disabling IPv6 but this made no difference.
Any further ideas?
