JBrander7
Mar 20, 2016Guide
NETGEAR A6210 Always google review before you buy!
I have been putting up with disconnects for around 4 months now. I have no idea where my receipt is, and the **bleep** cost me around $100.00 AUD.
After googling, I have discovered MANY people experience the same thing, however no solid solution for a fix.
Disgusting product.
- JamesGLMaster
Hi JBrander7,
May I know what is the model number or Netgear device you have?
And provide us brief explanation of the issue you are experiencing.
NETGEAR A6210 WiFi Adapter.
There are plenty of complaints in the forums regarding this device. If my WiFi doesn't drop out, it is absolute sluggish. I have to pull it out of 3 different USB 3.0 slots or standard 2.0 slots and put it back in so it can reset itself and run like normal. For 10minutes up to an hour.
Anything else?
Still no response.
- JamesGLMaster
Hi JBrander,
1. Do you have a Windows 10 OS?
2. What is the software version of your adapter?
3. Can you try to install it on a different computer and check if the same issue?
- Windows 7
Have installed latest software. Uninstalled device reinstalled. Removed driver and placed mediatek driver. Un-installed using cd software. Tried all methods available. Your device is just **bleep** ☺
Have tried on a desktop and a laptop. Drop outs allll dayyy - Smart TV. PS4. XBOX One. WII U. Mobile phones and Tablets.
The amount of devices connected at any times to the wireless router would be 3 maximum. But I have tested this and it's still dropped out being the only device.
I have only ever see ln the connection speed at 300mbps once. Otherwise it's around 144.- AndrewF80Aspirant
Dont ever be fooled by the displayed "connection speed" as it rarely has any bearing on actual performance.
I also have the 6210 and it makes my PC freeze up, requiring a reboot. So I'm in a similar boat with this substandard product. My old Belkin works. Slowly, but reliably.
For me Windows 10 is a piece BLEEP but not the device, I installed it on my dad's Win 10 HP envy 13 witch has a really **bleep**ty inboard wifi card and it improved far better the bandwidth. From 6Mbps to 45Mbps not bad and nearly no disconnection. I even tested on a 350 Gb folder (I have to waste some time :smileylol:) and it did it!
