Pleb
Feb 01, 2019Follower
Netgear AC1200 USB WiFi Adaptor
Can the AC 1200 be plugged into my Xbox One X to make my WiFi connection stronger or does this only work for a PC
1 Reply
Pleb wrote:
Can the AC 1200 be plugged into my Xbox One X to make my WiFi connection stronger or does this only work for a PCNo. And Yes,
You cannot plugged a wifi adapter into an Xbox One X.
It only works on a PC.
