NeedHelpBCimDum's avatar
Jul 11, 2017
NETGEAR genie A6200 problems; Red light appears and wont go away on the adapter.
Hey there everyone!   My name is Ben and i bought a custom PC on ebay. The thing is that it was custom built and could not connect to the internet the regular way, so he sent me a D - link, unforun...
  • JamesGL's avatar
    Jul 17, 2017
    Hi NeedHelpBCimDum,
    Try to install it on a different computer and check if the same problem.
