Aardvark135
Nov 23, 2017Aspirant
Netgear genie A6210, Ethernet wont work after using this device
So I have a windows 10 pc I built myself with a couple friends. I didnt have a NIC so I bought this device to use until I ran an ethernet cable up to my room. I finally got around to running it becau...
- Nov 24, 2017
You managed to find a motherboard that didn't have a LAN port?
Aardvark135 wrote:
but when I plugged it in it recognizes that it's plugged in the ethernet 2 port but says it's an unidentified network and that there is no internet access.
That is a Windows error. Run the network troubleshooter.
Check that you have set the Network "private".
Aardvark135 wrote:
I looked around online and found a page in this board that says once installed this device will permanently remove Windows 10’s ability to access the WiFi Connections list.
That message dates back to 2015.
Do you have the latest LAN drivers for your PC? They rarely ship with the hardware. As this is a home made PC, you should be able to get the latest chipset drivers from the maker's support pages.
Aardvark135
Nov 24, 2017Aspirant
Ok, so installed the new driver from MSI's website and it still didn't work, but I unistalled it and reinstalled it and now it's working perfectly. The A6210 device must've changed something so that it could read from a USB port, but starting fresh fixed the issue.
Thanks for the assistance, this is an issue that has been bothering me for many weeks, mostly becuase I'm a gamer and the ping was just awful, but I'm hoping this will help. Again thanks so much, have a good one.
michaelkenward
Nov 24, 2017Guru - Experienced User
Good luck.
Some users avoid gaming over wifi because they find it less reliable.
- Aardvark135Nov 24, 2017AspirantPrecisely the reason I'm trying to get my ethernet up, thanks man.
- michaelkenwardNov 24, 2017Guru - Experienced User
If the wifi is flaky, and it is difficult to run a LAN cable, the Powerline Ethernet might work. It is certainly fine for smart TVs and stuff like that. Not sure how it plays with games.
