DukeNukeum
Apr 04, 2016Aspirant
Netgear Genie keeps poping up
Yesterday my Netgear Genie Auto Updated the software on my computer which is a Windows Vista Gateway Desktop and ever since it was updated whenever I reboot my computer the Netgear Genie keeps poppi...
- Apr 17, 2016
Hi DukeNukeum,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Apr 10, 2016NETGEAR Employee Retired
Hi DukeNukeum,
Try to uncheck it on the start up of your computer. Also, if you don't want to use the Genie, you may uninstall it.
- DukeNukeumApr 10, 2016Aspirant
Thanks I will try that then. If I have any more problems I'll be sure to post on here again.:smileyhappy:
- JamesGLApr 17, 2016NETGEAR Employee Retired
Hi DukeNukeum,
- DukeNukeumApr 17, 2016Aspirant
Actually that solution above didn't resolve the problem. In regards to checking it off since I couldn't find the part on the computer to do that. And I don't want to uninstall the genie since I need it on the computer since my desktop doesn't have wifi built into it like later models since mine is from 2007. But I think I will just let it go. It is not that big of a deal anyway. So I will just say solved then. Thanks for your help.
