FrankScar
Jun 12, 2018Follower
Netgear Genie software update not completing
I have the Netgear Genie AC1200 WiFi USB Adapter - current software 1.0.0.36. I did a check for a software update and was informed Software version 1.0.0.39 is available. I have made several attempts to download this software; however, each time the update gets to 95%, then returns to 70%. It is not completing. Please advise.
- Blanca_ONETGEAR Employee Retired
Hi FrankScar,
Welcome to NETGEAR Community!
May I please ask for the following information:
- Were you able to install WiFi Adapter using driver version 1.0.0.36?
- If so, do you have connectivity issue?
- Screenshot where it shows a new software update is available
I checked A6100 product support page, the latest driver version is 1.0.0.36.
Blanca
Community Team - Blanca_ONETGEAR Employee Retired
Hi FrankScar,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team - HerrjensenAspirant
Hey, I haf exactly the same problem. Got a notice in the Netgear Genie saying there was new software, I click it and it starts downloading, then a pop up came up saying I should click OK to download it and when I did that it failed to download further.
However, while trying to get screenshots for this post and thus waiting a bit before clicking OK, instead of doing it instantly like the other times I had tried, it actually completed the download and I was able to install without problems.
Seems weird if waiting a bit before clicking OK would be the solution, but it worked for me, and if nothing else I'd try a few more times.
Hi Herrjensen,
Thanks for posting this work around. Glad to hear that you got it working.
Blanca
Community Team
