ryuk52109
Apr 10, 2018Initiate
Netgear Nighthawk A7000 massive ping increase at random
Hello, I am having trouble with my Netgear Nighthawk A7000 USB adapter, for some reason, the ping randomly shotos up from 23-25ms to over 2000ms. I can easily tell when playing games because they la...
- Jul 18, 2018
Hey everyone, I'm writing this reply because I've fixed the problem and I'm hopeful this will work for you and for anyone that googles the same issue.
I have an A7000. It worked fine for a week or so and then started having lag spikes every 10-20 seconds. After trying everything and being unable to solve it, I came across something that worked for me:
I found a reddit post in which a user described the same issue and posted a solution. The summary: you need to disable autoconfiguration logic because our wifi cards are polling for new networks and that's what's causing the spike. Here's a link to the post: https://www.reddit.com/r/GlobalOffensive/comments/3ahg59/fix_for_wireless_ping_spikes/ and here's the content in its entirety:
in your windows cmd, type in
netsh wlan show settings
and one of the last things might say
Auto configuration logic is enabled on interface "Wireless Network Connection"
if that's the case, then type in
netsh wlan set autoconfig enabled=no interface="Wireless Network Connection"
It should respond with
Auto configuration has been disabled on interface "Wireless Network Connection".
If it doesn't, then you might have mistyped your interface=" part. Check in your adapter settings, you might have Wireless Network Connection 2 or 3 etc.
This will definitely stop your wireless card from searching for nearby networks and updating your signal quality when you're not asking it to- which is what is causing the spikes.
You will need to turn it back on if you disconnect or need to be able to find nearby networks again. To do so change disabled to enabled from the earlier command or copy pasta
netsh wlan set autoconfig enabled=yes interface="Wireless Network Connection"
Good Luck!
MJBgood
Jun 14, 2018Aspirant
I am having the same issues. It is sad considering that when I plug in a cheaper usb adapter it works perfect yet this more expensive one cannot be relied on. PLEASE someone help!!! Have reinstalled drivers, disabled RunswUSB, turn off option that allows pc to turn off device, and more!
Blanca_O
Jun 14, 2018NETGEAR Employee Retired
Hi All,
May I please ask for the following information:
- Computer's operating system
- Does issue happen on both bands?
- Brand and model of the router
Blanca
Community Team
- dillius1024Jun 14, 2018Star
Windows 7
Only on 5Ghz, though my 2.4Ghz and 5Ghz bands share the same SSID
Netgear Nighthawk X4S R7800
I feel like this started for me after the release of the latest R7800 Firmware (v1.0.2.52) so I'm starting to think this is more the fault of the router. Other devices seem to be having problems too.
- MJBgoodJun 15, 2018Aspirant
-Windows 10
-Yes, both bands
-Verizon Fios Quantum Gateway router
Most likely due to the wireless adapter, as a different much cheaper adapter works perfectly but at lower potential speeds.
