ryuk52109
Apr 10, 2018Initiate
Netgear Nighthawk A7000 massive ping increase at random
Hello, I am having trouble with my Netgear Nighthawk A7000 USB adapter, for some reason, the ping randomly shotos up from 23-25ms to over 2000ms. I can easily tell when playing games because they la...
- Jul 18, 2018
Hey everyone, I'm writing this reply because I've fixed the problem and I'm hopeful this will work for you and for anyone that googles the same issue.
I have an A7000. It worked fine for a week or so and then started having lag spikes every 10-20 seconds. After trying everything and being unable to solve it, I came across something that worked for me:
I found a reddit post in which a user described the same issue and posted a solution. The summary: you need to disable autoconfiguration logic because our wifi cards are polling for new networks and that's what's causing the spike. Here's a link to the post: https://www.reddit.com/r/GlobalOffensive/comments/3ahg59/fix_for_wireless_ping_spikes/ and here's the content in its entirety:
in your windows cmd, type in
netsh wlan show settings
and one of the last things might say
Auto configuration logic is enabled on interface "Wireless Network Connection"
if that's the case, then type in
netsh wlan set autoconfig enabled=no interface="Wireless Network Connection"
It should respond with
Auto configuration has been disabled on interface "Wireless Network Connection".
If it doesn't, then you might have mistyped your interface=" part. Check in your adapter settings, you might have Wireless Network Connection 2 or 3 etc.
This will definitely stop your wireless card from searching for nearby networks and updating your signal quality when you're not asking it to- which is what is causing the spikes.
You will need to turn it back on if you disconnect or need to be able to find nearby networks again. To do so change disabled to enabled from the earlier command or copy pasta
netsh wlan set autoconfig enabled=yes interface="Wireless Network Connection"
Good Luck!
colgor88
Jun 19, 2018Initiate
I am having the exact same issue.I know it isn't a router issue because every other device I have works fine. When I am gaming and I counted the seconds in between and it spiked at a consistent 12-13 seconds. It would move from about 50 ping to about 300 ping and then back to 50. My character would jump a good portion across the map along with all the other players, and this was suprisingly consistent between three different online games I was playing.
RShank
Jun 25, 2018Initiate
Same exact problem here, just got it this past sunday. A bit disappointed however when running into this issue. I do believe it is the adapter because my previous adapter (Netgear ac1200) works just fine. I have also tried the latest troubleshooting theories to no avail. Please keep this thread going in case there is a fix!! I will not be returning my product in hopes for better drivers to be released.
Windows 10
- evergreentrailJul 18, 2018Initiate
Good Luck!
