law45
Sep 20, 2018Tutor
NETGEAR Powerline AV200 XAV2001 Connection 'Open'
I am unable to make the wifi connection secure, it is currently open and anyone is able to use it. I have tried going on mywifiext.net and the adapter is detected, I have tried changing the wireless settings using the powerline utility and it fails. I am completely lost at what to do now and need some help.
Solved: Go into the network genie software, click network map then right click your wifi extender device, then press configuration and it will take you to the NETGEAR AP where you can change all your wireless settings from.
1 Reply
- law45Tutor
