JayantKochar
Jun 16, 2017Aspirant
Netgear Wifi Adapter
Do Netgear have a USB wifi adapter that works with Mac Book running Yosemite 10.10.5 OS? The Netgear web site only shows 2 models for laptop, both mention that they are compatible with Windows but do...
- Jun 27, 2017
OK thanks.... though I went to a store and they showed me some Netgear usb models that were Mac compatible.... but eventually I bought another brand. But thanks for the response.
JamesGL
Jun 21, 2017NETGEAR Employee Retired
Hi JayantKochar,
Yes that is correct that NETGEAR USB adapters are compatible with Windows based OS only. If your MAC computer has ethernet port, you may check WNCE4004 or WNCE3001.
JamesGL
Jun 27, 2017NETGEAR Employee Retired
Hi JayantKochar,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- JayantKocharJun 27, 2017Aspirant
