Retired_Member's avatar
Retired_Member
Apr 02, 2019
Netgear wireless adapter AC600
can you use a chrome book with the net gear wifi adapter
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Is this the A6100 Wireless AC Adapter?
    There is a manual and other support stuff for the A6100 at the end of this link:
    >>>> A6100 | Product | Support <<<<
    If the idea is to plug the A6100 into the USB socket on a Chrome book and connect to wifi, then probably not.
    As the Data Sheet shows, the System Requirements include "Microsoft® Windows® 7, 8, 8.1, 10, XP, Vista®".
