Buckhorn55
Dec 26, 2015Aspirant
Netgear Wireless N Adapter on Windows Vista N600 will not connect to my Neatgear router
Buckhorn55
I have verifed that I have the latest drive WNDA3100v3 I have installed the standalone driver.
Buckhorn55
Dec 29, 2015Aspirant
Log Name: System
Source: Microsoft-Windows-Diagnostics-Networking
Date: 12/29/2015 11:10:11 AM
Event ID: 6100
Task Category: (12)
Level: Information
Keywords: (2)
User: LOCAL SERVICE
Computer: bette-PC
Description:
Helper Class (AutoConfig Helper Class) Event:
Wireless Diagnostic Informational Event
Information for connection being diagnosed
Interface GUID: 036610a4-1aee-4dcc-974f-5b448028680e
Interface name: NETGEAR WNDA3100v3 N600 Wireless Dual Band USB Adapter
Interface type: Legacy
Profile: Discovery connection
SSID: House_Full_Of_Paws
SSID length: 18
Connection mode: Infra
Security: Yes
Connect even if network is not broadcasting: No
Connection incident diagnosed
Auto Configuration ID: 12
Connection ID: 12
Connection status summary
Connection started at: 2015-12-29 11:08:53-926
Profile match: Success
Pre-Association: Success
Association: Fail
Security and Authentication: Not started
List of visible access point(s): 2 item(s) total, 2 item(s) displayed
BSSID BSS Type PHY Signal(dB) Chnl/freq SSID
00-26-5A-FC-20-A4 Infra g -46 6 House_Full_Of_Paws
A0-63-91-EE-08-FB Infra g -89 6 creeksideranch
Connection History
Information for Auto Configuration ID 13
List of visible networks: 2 item(s) total, 2 item(s) displayed
BSS Type PHY Security Signal(RSSI) Compatible SSID
Infra g Yes 100 Yes House_Full_Of_Paws
Infra g Yes 22 Yes creeksideranch
List of preferred networks: 1 item(s)
Profile: House-Full-Of-Paws
SSID: House-Full-Of-Paws
SSID length: 18
Security: Yes
Set by group policy: No
Connectable: No
Reason: 0x00028002
Information for Auto Configuration ID 12
Infra g Yes 26 Yes creeksideranch
SSID length: 18
Security: Yes
Connectable: No
Reason: 0x00028002
Information for Connection ID 12
SSID length: 18
Security: Yes
Pre-Association and Association
Connectivity settings provided by hardware manufacturer (IHV): No
Security settings provided by hardware manufacturer (IHV): No
Profile matches network requirements: Success
Pre-association status: Success
Association status: Fail 0x00038003
Association reason code: 0x00000000
Information for Auto Configuration ID 11
List of visible networks: 3 item(s) total, 3 item(s) displayed
Infra g Yes 26 Yes NETGEAR69
Infra g Yes 16 Yes creeksideranch
SSID length: 18
Security: Yes
Connectable: No
Reason: 0x00028002
Information for Connection ID 11
Connection started at: 2015-12-26 11:06:00-714
Auto Configuration ID: 11
SSID length: 18
Security: Yes
Event Verbosity:0
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Diagnostics-Networking" Guid="{36c23e18-0e66-11d9-bbeb-505054503030}" />
<EventID>6100</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>12</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000002</Keywords>
<TimeCreated SystemTime="2015-12-29T18:10:11.301Z" />
<EventRecordID>194406</EventRecordID>
<Correlation ActivityID="{28248EC7-B42F-4773-8ED4-FD2FC024B2AC}" />
<Execution ProcessID="2124" ThreadID="4112" />
<Channel>System</Channel>
<Computer>bette-PC</Computer>
<Security UserID="S-1-5-19" />
</System>
<EventData>
<Data Name="HelperClassName">AutoConfig Helper Class</Data>
<Data Name="EventDescription">Wireless Diagnostic Informational Event
SSID length: 18
Security: Yes
Connection ID: 12
Association: Fail
Connection History
SSID length: 18
Security: Yes
Connectable: No
Reason: 0x00028002
SSID length: 18
Security: Yes
Connectable: No
Reason: 0x00028002
SSID length: 18
Security: Yes
SSID length: 18
Security: Yes
Connectable: No
Reason: 0x00028002
SSID length: 18
Security: Yes
</Data>
<Data Name="EventVerbosity">0</Data>
</EventData>
</Event>
