marcycn
Jan 05, 2018Aspirant
Netgear Wireless-N Dual Band
I have this stick that I use to use years ago on a desktop I had. I now want to install it on a Dell Desktop and can't figure out how. I looked for a CD but couldn't find one. I push the button bu...
- Jan 05, 2018
Found what I needed and it worked. Thanks.
marcycn
michaelkenward
Jan 06, 2018Guru - Experienced User
For anyone who finds this discussion and its misleading "Solved" tag, the way to solve the problem is to put your model number into this page:
You can then find all the software, including drivers for Windows, and documentation for your hardware.
