Boater1
Apr 03, 2016Follower
NetGear wireless PCI Adapter - upgrade
New to the site. I have an older computer running Window with the 108 MBPS wireless pci adapter (WG311TNA). What would be a good adapter (newer version of PCI - which product) or USB? Secondly, I o...
TheEther
Apr 03, 2016Guru
I don't think Netgear makes PCI based Wi-Fi adapters any more, so you will have to look at other brands.
Netgear's USB based adapters are here (link). Any adapter should work, so long as it supports your computer's operating system. If you want something well matched to the capabilities of your Wi-Fi router, then you'll have to provide the model number of your router.
