Riverrider2
Mar 01, 2017Aspirant
Netgear WNA3100 not compatible with Netgear router?
I'm running a R7000 wireless router and have routinely connected to it via www.routerlogin.net to configure settings. I had previously used an old Linksys wireless G adapter to connect. I decided t...
JamesGL
Mar 03, 2017NETGEAR Employee Retired
Hi Riverrider2,
1. What is the OS of your computer?
2. What is the driver version of the adapter?
3. Try to uninstall and reinstall the driver.
Riverrider2
Mar 03, 2017Aspirant
The computer is running Win7. The WiFi adapter is running firmware v2.2.0.4 and the router is running firmware v 1.0.7.10. I'm runing Kaspersky Total Security for anti-virus protection.
- JamesGLMar 06, 2017NETGEAR Employee Retired
Hi Riverrider2,
Please check this KB article and see if that helps.
http://kb.netgear.com/30012/Unable-to-access-router-management-page-with-Kaspersky-installed
- JamesGLMar 09, 2017NETGEAR Employee Retired
Hi Riverrider2,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Riverrider2Mar 09, 2017Aspirant
So far the efforts have been fruitless. I have uninstalled and re-installed the adapter, but am still unable to log in to the router using it. I have tried turning off the anti-virus protection software, but it made no difference. If I use a different computer (ASUS laptop, Win10 with factory WiFi adapter) running the same version of Kaspersky, I am able to log into the router.
- JamesGLMar 10, 2017NETGEAR Employee Retired
Hi Riverrider2,
Can you access it if using the IP address of the router(ex. 192.168.1.1)?
- Riverrider2Mar 10, 2017Aspirant
I can access the router login page using the IP address from other computers. I was also able to do that before I installed the WNA3100.
