Riverrider2
Mar 01, 2017Aspirant
Netgear WNA3100 not compatible with Netgear router?
I'm running a R7000 wireless router and have routinely connected to it via www.routerlogin.net to configure settings. I had previously used an old Linksys wireless G adapter to connect. I decided t...
JamesGL
Mar 03, 2017NETGEAR Employee Retired
Hi Riverrider2,
1. What is the OS of your computer?
2. What is the driver version of the adapter?
3. Try to uninstall and reinstall the driver.
JamesGL
Mar 14, 2017NETGEAR Employee Retired
Hi Riverrider2,
Uninstall the drivers of the adapter. Reinstall it using the standalone driver.
- JamesGLMar 17, 2017NETGEAR Employee Retired
Hi Riverrider2,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Riverrider2Mar 18, 2017Aspirant
I tied uninstalling the driver and installing the stand alone driver supplied on the disk. There was no change. Connecting via the Genie app, the URL or the IP address all continue to fail. In each case the app or the broweser says it can't find the router.
From Firefox:
The connection to the server was reset while the page was loading.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.From Netgear Genie:
NETGEAR router is not found or is not supported.
- JamesGLMar 27, 2017NETGEAR Employee Retired
Hi Riverrider2,
Can you ping the IP address of the router?
