Mkveli2pac
Aug 29, 2015Aspirant
NetGear wnda 3100v2 connections issues since Windows 10
Ever since I downloaded Windows 10, my wnda 3100v2 adapter loses connection randomly. I have download the latest firmware and it has not solved the problem. When the connection goes out, the adapte...
JamesGL
Sep 01, 2015NETGEAR Employee Retired
Hi Mkveli2pac,
Welcome to Community!
Have you tried installing the standalone driver instead of the driver with the Genie?
JamesGL
Community Team
- BaJohnSep 01, 2015Virtuoso
I have the same adapter and the same problems.
The standalone driver has a higher (later) version, but in my case just makes the problem worse.
It is listed as 2.2.06 not 2.2.05 which is kinda weird, as it is a Zip for 2.2.0.5?
MKveli2pac
Please just to satisfy my curiosity, can you start up a DOS session.
Right click <Start> and choose command prompt (admin).
Then type "netcfg -s n" and under the Network Adapters copy and paste the info here.
It will probably, on a good system be 2 or 3 items/lines.
Should take about 1 minute tops.
Thanks
- Mkveli2pacSep 02, 2015Aspirant
BaJohn here is the info you requested:
Network Adapters
-----------------usb\vid_0846&pid_9011 NETGEAR WNDA3100v2 N600 Wireless Dual Band USB Adapter #2
pci\ven_14e4&dev_16b1 Broadcom NetLink (TM) Gigabit Ethernet
usb\vid_0bb4&pid_0fb4&mi_00 HTC Remote NDIS based Device
