paladino2
Jan 03, 2016Aspirant
NETGEAR WNDA3100 V2 Stopped working
After 3 years my NETGEAR WNDA3100 V2 stopped working. One day at my pc when i was downloading a file (1,50GB), the adapter shutted down e never came up, the led not turn on... no signal of life... ç...
- Jan 12, 2016
If same problem with another computer, probably the device is no longer working.
JamesGL
Jan 06, 2016NETGEAR Employee Retired
Hi paladino2,
Can you check on device manager under network adapters if you can see the adapter? If not, try to connect it on a different computer and install it.
- paladino2Jan 07, 2016Aspirant
Hi JamesGL thanks for your answer. I checked on device manager under network adapters and i can't see nothing about the adapter WNDA3100, i can see just the ethernet card. I tried the same steps under 2 other computer but nothing.... Now i'am thinking that the adapters is burned....Any other ideas JamesGL?
- JamesGLJan 12, 2016NETGEAR Employee Retired
