ftgml
Jun 22, 2022Follower
Netgear WNDA3100v2 no longer connect to Wifi network
The old Netgear WNDA3100 v2 USB Wifi adapter used to be able to connect to both 2.4Ghz and 5G FIOS wifi. However, it no longer doe that. The only time it recognizes the 2.4 home network is when it is next to the router and the WPS button on the router is pressed shortly after the button on the adapter is pressed. However, once it is unplugged and repluged, it will not longer find the wifi network.
Toshiba Statellite C75D-B7360, Win10 latest update, internal network adapter 2.0 Ghz, up to 2.4Ghz. Verizon FISO Gigabit, Quantum g1100 touter.
Both the card and the laptop are old. However, since the card used to work on both channels, but it no longer work on either, I am trying to find out if ther eis a way to make it work. Any suggestions would be greatly appreciated. Thanks.
1 Reply
have you tried it on a different device?
