jlipschitz's avatar
jlipschitz
Follower
Jun 07, 2023
Netgear WNDA3100V3 in Windows 11
The Netgear official drivers do not work in Windows 11.  They will not even install.  They state that they are for Windows 10 anyways.  If you are trying to get your WNDA3100V3 to work in Windows 11, you can install the chipset driver that is built into Windows 11 to make it work.
  1. Plug the adapter into any USB port
  2. Log in as an administrator
  3. Right click on the Start button and select Device Manager.
  4. Double click on WNDA3100v3 under Other Devices
  5. Click on the Driver Tab
  6. Click Update Driver
  7. Click Browse my computer for drivers
  8. Click Let me pick from a list of available drivers on my computer
  9. Select Network adapters and click Next
  10. Select MediaTek, Inc.
  11. Select 802.11n USB Wireless LAN Card and click Next
  12. Click Yes on the Update Driver Warning
After that, it should work in Windows 11
#wnda3100v3
No RepliesBe the first to reply
