richard105
Oct 25, 2018Follower
netgrar nighthawk ac1900
I purchased a netgear wifi adapter NightHawk AC1900. I was instructed not to plug in the device into the usb until the installation CD was run. I have no external or internal cd drive for PC (only ...
- Oct 28, 2018
Hi richard105
Welcome to NETGEAR Community!
Kindly download the driver from this link https://www.netgear.com/support/product/A7000.aspx#download
Once done, open the file, run the .exe file and follow the onscreen instruction.
Blanca
Community Team
Oct 25, 2018Guru - Experienced User
You must mean the A7000 adapter. I'm moving your post to the correct forum for wifi adapters.
You can try contacting Netgear support via my.netgear.com.
