AmberJay
Jul 20, 2018Aspirant
Nighthawk A7000 software or standalone driver?
I'm installing the Nighthawk AC1900 Model No. A7000 for my laptop which is running windows OS 10. I don't know the difference between choosing the Adapter Software or the Standalone Driver. Can someo...
michaelkenward
Jul 21, 2018Guru - Experienced User
I'd try plugging the thing in and seeing of Windows installs its own drivers. That works for some people.
- mondenathJul 21, 2018Prodigy
Standalone works fine. Dont Install 15 latest unless 11 is having issues. I believe 15 have some issues.
If the drives are properly installed you will get good speed like this with top end ac router setup and no interfernace
