Dave1973
Mar 09, 2019Aspirant
No internet connection with A6100 usb network adapter
My Asus notebook has network connection problems so I purchased the Netgear A6100 usb wireless network adapter and plugged it into my notebook after setting it up properly. It is connected to my WiFi...
Dave1973
Mar 10, 2019Aspirant
Can anyone help me with a solution please?
- michaelkenwardMar 10, 2019Guru - Experienced User
It is the weekend. The tech-support team won't be here. The rest of us are relaxing.
Try running the Network Troubleshooter in Windows.
My first guess based on the minimal information you provided is that you need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
- Dave1973Mar 10, 2019Aspirant
Thanks for the reply. I am in the network & internet status, but I don’t see change connection properties.
When I run the troubleshooter I get a message “the diagnostics policy service is not running”
This is what I see
Pictures need admin approval before they appear here.
In Windows 10, I see this:
See the Private network bit?
