arkadio
Aug 01, 2016Aspirant
Panasonic TX-P42VT30E
Which WiFi adapter is compatible with Panasonic TX-P42VT30E?
JamesGL
Aug 07, 2016NETGEAR Employee Retired
Hi arkadio,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
arkadio
Aug 08, 2016Aspirant
Hi James,
could you recommend adapter compatible with exactly this tv type?
I couldn't find exactly this type on the adapters list.
will the one you have recommended (WNDA3100v2) work with TX-P42VT30E?
Best Regards,
Arkadio
- JamesGLAug 09, 2016NETGEAR Employee Retired
Hi arkadio,
If your TV has an ethernet port you may try the following adapters.
-WNCE3001
-WNCE4004
If it does not have any ethernet port then no other USB adapters will work with the TV.
JamesGL
Community Team
- JamesGLAug 16, 2016NETGEAR Employee Retired
Hi arkadio,
JamesGL
Community Team
