Gmodmaster
Nov 24, 2020Follower
Problems, Netgear A6100
I been Useing This Netgear And with games...
#1 The Problem is.. Disconnecting, From. Adapter... Stops, And, Go. About, 19 To 20 Minute, in Game, :when: in. a Match... or. Server...
#2 The Router is different soo idk what router...
#3 i just wanna play becasue i play other games that i like and i dont know what to fix this problem...
#4 Plz. Plz! solve this problem if you know the problem is and i cant figure out when it stops the thing and go... and i been using discord for my calls and they stop too when i join and they stop for like.. 38 seconds TO.. 13 Mins
1 Reply
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
Check the troubleshooting section in the manual.
