Clentis's avatar
Clentis
Follower
Jan 17, 2019
Problems with A6210
I recently purchased a AC1200 WiFi USB Adapter Model No. A6210 from Target in Memphis, TN. Shortly after installing this product I ran a scan on my desktop using HitmanPro 3.8.0. The scan indicated that my computer had a Trojan that originated from Netgear A6210. The HitmanPro removed the Trojan, and I uninstalled the A6210 from my PC. After it was uninstalled, I reinstalled the A6210. After the reinstallation I ran another scan with HitmanPro and it again indicated that my PC had a Trojan that originated from the A6210. I again uninstalled the A6210 from my computer. I then ran another scan, just to be safe, and the scan indicated no Trojan.
Has anyone else had this problem, and if so, how did you handle it? Should I contact Target to see if I can get a refund, or Netgear to see what they will do?
Thank you for your help.
1 Reply
