Nirvania's avatar
Nirvania
Problems with package loss on A6210
Hi everyone
I am experiencing some issues with my A6210 wifi usb adapter.
The windows event logs are constantly giving me errors from the A6210 device saying the following:
"NETGEAR A6210 WiFi USB3.0 Adapter: The network card is configured so that the receiving space is smaller than the smallest packet size. Packages can be dropped."
Everytime i get this error my internet connection is cut off and after 20-30 seconds the internet is back up and running again.
This happens randomly, sometimes it happens 10 times in only 1 hour and sometimes it can take several hours between the first error and the next one.
Does anyone know a solution or what could be behind this?
Everything has worked just fine for years running this device, it is only just recently that i started getting these problems.
My software for this device is up to date running the latest version: 1.0.0.39
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Nirvania
    Welcome to NETGEAR Community!
    What is the Operating System of the computer? You mentioned that it was working fine for years, was there any changes / updates done on your PC?
    Have you tried to uninstall and reinstall the driver?
    Please follow the steps from this link:  https://kb.netgear.com/23352/
    Blanca
    Community Team
    • Nirvania's avatar
      Nirvania
      Hi
      No, there haven't been any changes to my computer, maybe a few windows updates but that's it pretty much.
      I am running windows 8.1
      It seems like though my problem is limited to the 1.0.0.39 version. I tried uninstalling and reinstalling it but didn't work.
      Because when i downgraded from 1.0.0.39 back to 1.0.0.25 all my issues suddenly disappeared.
    • Blanca_O's avatar
      Blanca_O
      Hi Nirvania
      Thank you for the update. We would like to look into this issue. If you are willing to work with support on the issue, please let me know and I will PM you requesting for more information.
      Blanca
      Community Team
