eszry
Oct 02, 2015Aspirant
A6200 and WPA/WPA2 RADIUS Security
Hoping that someone can help me. Have a vista computer used by students to access the Internet- specifically for Reading Eggs. Has an old dongle that worked well. Have changed the security since and...
Babylon5
Oct 03, 2015NETGEAR Employee Retired
I don’t own an A6200, so can’t be sure if this helps, but you may find that if Radius connections are supported there should be related options in the Advanced Properties for the device. This might help in finding those settings;
