ceven
Apr 28, 2023Aspirant
A6210 Constant Disconnecting
Netgear A6210 Wifi Adapter in USB 3.0 port Windows 10 Pro version 21H2 Specs too good to be relevant whatsoever Constant disconnecting (USB sound) and disconnecting when attempting speedtest ...
michaelkenward
Apr 30, 2023Guru - Experienced User
ceven wrote:
I have ordered a TP-Link PCIE option, which by reviews looks much more reliable, and I doubt the customer service will try to get me to buy a monthly service for a singular month just to tell me the product is old and faulty.
Does it support WiFi 6?
I needed something for beta testing a router with WiFi 6E. I opted for a WavLink WiFi 6 AX3000 PCI-E Adapter. It also does Bluetooth.
ceven
Apr 30, 2023Aspirant
The TP-Link TX3000E supports Wifi 6 and Bluetooth, I decided against the 6E version because im not sure of the compatibility with my mobo, and I don't wanna upgrade to Windows 11. I like my hashed out Win10.
I recently, like the null skull I am, purchased a NETGEAR Nighthawk AX3000 (RAX39 or something) on FB marketplace AFTER my whole debacle with my adapter. I shouldve known I would have yet another sour experience. The sucker was a pain in the ass to setup, but when I set it up correctly, one of my devices got a whopping 1 mbps connection on the 2.4ghz band, whereas before with the crappy Spectrum-issued router it got usable speeds. Truly truly disappointed in this brand and I am very curious how they havent plummeted off all the shelves as every experience I have had with NETGEAR is janky, and I cant rely on a support agent to help me with their jank, because I dont have the money to pay their monthly tech support costs.
