magnet0
Oct 09, 2026Aspirant
A9000/BE6500 Wifi-7 support MLO
Hi, Does the new Wifi7 usb adapter support MLO connection on tri-band? No mention of it in the data sheet. https://www.netgear.com/home/wifi/adapters/a9000/ Thanks
Oct 09, 2026Guru - Experienced User
It doesn't...I have one as well. Just 6Ghz max.
- magnet0Oct 10, 2026Aspirant
Thanks FURRYe38,
What is the point of advertising as Wifi 7 triband if MLO is not supported?
- StephenBOct 10, 2026Guru - Experienced User
MLO isn't the only upgrade over WiFe 6e.
The A9000 supports both 320 Mhz channels and 4K QAM modulation.
Thanks StephenB, I noted that in ds, but i need to know if MLO is supported, its not advertised in ds. Thanks again
