magnet0
Oct 09, 2026Aspirant
A9000/BE6500 Wifi-7 support MLO
Hi, Does the new Wifi7 usb adapter support MLO connection on tri-band? No mention of it in the data sheet. https://www.netgear.com/home/wifi/adapters/a9000/ Thanks
magnet0
Oct 11, 2026Aspirant
Thanks for the detailed reply.
I need all the features you have listed in your reply for my day-to-day work and testing purposes, especially MLSR and MLO.
The online datasheet does not mention in detail all the technical capabilities of the Wi-Fi 7 USB adapter. It's a high-priced item, so I need to make sure that if I buy it, it will be worthwhile and support all of the Wi-Fi 7 features.
Thanks again.
schumaku
Oct 11, 2026Guru - Experienced User
magnet0 wrote:It's a high-priced item
A WiFi 7 client device with these features comes with a double price tag of the A9000 - more WiFi chips, more bandwidth, more USB power, the required heat dissipation, ...
