Leggo0
Apr 10, 2018Follower
Device undetected after computer wakeup
Recently, after going to use my desktop after waking the computer up from sleep, my A6210 will be undetected. The only way I have found to fix it is to unplug the antenna from the docking base on my ...
itsjustfrank
May 12, 2018Aspirant
I thought I had made it clear in my post that I tried this solution. Apologies if I hadn't. This does has no effect on my issue. When resuming from sleep the device is still unresponsive.
JamesGL
May 31, 2018NETGEAR Employee Retired
Hi itsjustfrank,
Have you tried it on a different computer?
