Ronfirst
May 15, 2017Aspirant
Region change?
Smart Wizard shows Reg Domain as Australia ... scanning doesn't find anything ... I'm in New Zealand ... How do I change the setting, please?
- May 25, 2017
Hi Ronfirst,
Install the adapter without the smart wizard. Use the Windows wireless utility to search for wireless network.
Ronfirst
MODEL is WG111v3 - this was deleted when question was posted
- JamesGLMay 17, 2017NETGEAR Employee Retired
Hi Ronfirst,
Try to use a different driver.
http://downloadcenter.netgear.com/en/product/WG111v3#searchResults
- RonfirstMay 18, 2017Aspirant
Thanks - but not very helpful.
I've downloaded the driver specified for my Op System (Ms W7) and the WG111v3.
Are you suggesting I download something else?
- JamesGLMay 25, 2017NETGEAR Employee Retired
Hi Ronfirst,
