GaryLex99
Aug 22, 2017Aspirant
Replace the WiFi Internet Adapter WNCE2001
 What can I get to replace the WNCE2001 adapter?
michaelkenward
Aug 23, 2017Guru - Experienced User
What's the scenario? What do you want to connect to what?
Maybe there is a newer technology that can fill the bill.
GaryLex99
Aug 23, 2017Aspirant
I was using the Netgear WNCE2001 for WiFi to my Panasonic Viera TC-P50S30 TV that does not have built-in wireless. Since the TV was preloaded with online porgrams like Amazon, Facebook, etc., I do not need a Fire Stick or Hulu or the like. Just need a similar internet adapter that has the ethernet connection for the TV.
- michaelkenwardAug 23, 2017Guru - Experienced UserI use Powerline Ethernet for that. I find it easier to set up and more reliable than wifi. XAVB5221 | Powerline | Networking | Home | NETGEAR You could also add a wifi access point in the same room as the TV if that is any use. XWNB5201 | Powerline | Networking | Home | NETGEAR It works like this: - put "host" plug into power socket near modem/router
- connect host plug to router's LAN socket
- put "client" plug into socket near TV
- plug TV LAN into LAN socket on plug.
 If you are short of plug sockets, look at the passthrough option. XAVB5421 | Powerline | Networking | Home | NETGEAR These are the older, and cheaper, options. They have 100 Mbps LAN sockets. Newer plugs have 1000 Mbps, but that is probably faster than your TV's LAN, and faster than you need. Even 100 Mbps is likely to be seriously faster than wifi. I suspect that the device you want to replace is a thing of the past. - GaryLex99Aug 23, 2017AspirantSounds like a good idea but the XAVB5221, XWNB5201, and XWNB5221 all seem to be discontinued or are unavailable. - michaelkenwardAug 23, 2017Guru - Experienced UserIn that case, you may have to buy the newer versions.They will work, even if the TV can't make the most of the LAN speed. But you never know what your next TV will be like. But Netgear isn't the only maker of Powerline devices. The good news is that you can mix different makes and different generations of plugs.
