GaryLex99
Aug 22, 2017Aspirant
Replace the WiFi Internet Adapter WNCE2001
What can I get to replace the WNCE2001 adapter?
michaelkenward
Aug 24, 2017Guru - Experienced User
GaryLex99 wrote:I'll give that a try...any recommendations??
Your call really.
I would look at the same brand that you have as a router/modem. I say that because the utilities that work with one may work with the other. For example, the Netgear genie can map all devices on the network. Whereas my second network has a different modem and I can't view the whole network on one app.
GaryLex99
Aug 26, 2017Aspirant
Thanks for the advice. Just purchased a Netgear Powerline 1000 (Model PL1000v2) and had it set up and working in about 10 minutes! Thanks again...
- michaelkenwardAug 26, 2017Guru - Experienced User
Excellent news.10 minutes must be some sort of record.
I am envious. I have older generation plugs. They aren't as fast as yours, but they do the job, so what the heck?
