p3x982
Feb 22, 2018Follower
Replacement Usb Power Cable
Have bought a WNCE2001 off eBay to replace a Yamaha YWA-10 but it didn't have the usb power cable. The Yamaha one doesn't fit as the plug is too big so was wondering if someone could tell me the exact size cable I need. Have googled it but came up empty.
1 Reply
It is probably a universal size of the sort that you can find in many electrical stores.
There is a manual for the WNCE2001 somewhere at the end of this link:
>>>> WNCE2001 | Product | Support | NETGEAR <<<<
Unfortunately, the but that tells you what to do (page 5) isn't much help, so it is probably a case of taking it with you and trying to find a match.
