mearsma's avatar
mearsma
Server Operating Systems and NetGear wireless adapters
Do any wireless adapters work with the Windows Server 2012 R2 operating system?
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi mearsma,
    NETGEAR adapters only works with normal Operating System like Windows XP, Vista, 7, 8 and 10. You may try to check  WNCE2001, WNCE3001 or WNCE4004.
  • I'll have to go to another vendor. Thanks!
