kuroikain
Aug 23, 2017Follower
Slow Wireless speeds A6100
So the issue I'm having is, when using the A6100 My speeds are horrible I'm talking less than a meg down usually sits around 500KB/s.
I noticed this seems to be an issue related with Windows 10 but I can't find any way shape or form to fix the issue. If anyone has any advice it would be greatly appreciated.
1 Reply
Did you check for updated drivers?
>> Click here >> A6100 | Product | Support | NETGEAR << Click here <<
