Joel_Cairo
Sep 25, 2016Aspirant
Strange Alert over and over: "NETGEAR Genie - Reinstall/upgrade complete"
Howdy- I don't know a whole lot about network adapters, but I have a new Dell workstation running Windows 10, and a Netgear Genie WNA1100. Since I got a notice that there was a newer driver availabl...
- Oct 19, 2016
Hi Joel_Cairo,
Run the program to uninstall the driver before deleting the folder.
JamesGL
Community Team
Joel_Cairo
Sep 30, 2016Aspirant
Here ya go:
Nado82
Oct 09, 2016Aspirant
I am getting the same message several times a day. Is there any way to disable it? Clicking
the OK button doesn't seem to do the trick.
- JamesGLOct 09, 2016NETGEAR Employee Retired
Hi All,
Can you remove the NETGEAR folder under the program files and see if the same thing happens.JamesGL
Community Team
- Joel_CairoOct 09, 2016Aspirant
Umm... there's a LOT of stuff in that folder, .dll files, an application (WNA1100), etc. Are you very certain you want me to trash this folder? Woundn't dumping these files effectively kill the program, and my ability to be wireless? Just checking before I act!
- JamesGLOct 11, 2016NETGEAR Employee Retired
Hi Joel_Cairo,
Uninstall first the driver then remove the folder. Reinstall the driver afterwards.
JamesGL
Community Team
