BUZ
Oct 26, 2015Aspirant
Strange dns query from netgear adapter
I just started using a netgear wireless adapter on one of my windows 7 desktop machines and noticed a google dns query being sent (after I enable the adapter). Does not do this if using an ethernet c...
JamesGL
Oct 30, 2015NETGEAR Employee Retired
Hi BUZ,
When you check the IP settings of your computer, what is the DNS server? Is it the google DNS server IP? What is the model number of your adapter?
JamesGL
Community Team
- BUZNov 02, 2015Aspirant
Hello,
When I check via dnsleaktest.com I see my isp DNS, confirmed via my wireless adapter that the dns is not set to use anything else, checked ipconfig /all in CMD and I see 192.168.1.1. Checked router setings and it's not set to use google dns (only isp).
When I run wireshark and enable the adapter (netgear wna1100) I immediatly see a two google dns querys every time then random ones every so often. I though that maybe it had something to do with automatic updates being enabled so I disabled updates however still does it. When I disconnect the wireless adapter and plug in ethernet cable I do not see the google dns querys so I assume it has something to do with the netgear adater?
- BUZNov 10, 2015Aspirant
Any ideas???
- JamesGLNov 11, 2015NETGEAR Employee Retired
Hi BUZ,
Can you try to install it on a different computer and see if that sends Google DNS query? There might be a program on your computer that sends query.Regards,
JamesGL
Community Team- BUZNov 12, 2015Aspirant
Hello,
I removed the netgear adapter and tried two other wireless usb adapters on my machine (no longer saw any google dns query(s). As soon as I re-installed the netgear adapter on my machine I saw the dns query(s) again. So it has to be the netgear adapter.
