TerryL
Aug 28, 2015Aspirant
Trying to install WNA3100.
When I get to the join a network step, the choices are blank. There is no WPS button on my router and I don't know how to find the SSID of the connection I am using to connect manually. How can I con...
JamesGL
Aug 29, 2015NETGEAR Employee Retired
Hi TerryL,
Welcome to Community!
If you know how to configure your router, you may try to enable SSID brodcast just to connect the wireless adapter to the network. Once connected you may disable it again of you don't want it to be shown. If you want to manually add it you may try the link below for Vista, Windows 7 and Windows 8.
JamesGL
Community Team
TerryL
Aug 29, 2015Aspirant
I tried that, but in step 4 it asks you to input the name of network (SSID), Security type, encryption Type and Security Key and I don't know where to get that information.
