AntMusic
Jan 26, 2017Aspirant
Trying to use Netgear N150 for digital mixing desk
Can I use the Netgear N150 USB micro adapter with a QSC Touchmix 16 digital mixing desk to create a local network for my iPad to join? It will not be connected to the internet, I just need wireless c...
- Feb 14, 2017
Thanks for the advice - I've got it sorted now.
JamesGL
Jan 31, 2017NETGEAR Employee Retired
Hi AntMusic,
The adapter will only work with Windows based OS computers.
AntMusic
Jan 31, 2017Aspirant
Many thanks for the update. I got it working well on a laptop, but in the end I bought a simple TP-Link 150Mbps N Nano USB adapter and it did the job on the QSC Touchmix 16. I couldn't see anything that says the Netgear N150 can only be used on a Windows based computer though, even after reading all of the instructions.
- JamesGLFeb 10, 2017NETGEAR Employee Retired
Hi AntMusic,
You can check the Tech Specs of the device.
