AntMusic
Jan 26, 2017Aspirant
Trying to use Netgear N150 for digital mixing desk
Can I use the Netgear N150 USB micro adapter with a QSC Touchmix 16 digital mixing desk to create a local network for my iPad to join? It will not be connected to the internet, I just need wireless c...
- Feb 14, 2017
Thanks for the advice - I've got it sorted now.
AntMusic
Jan 31, 2017Aspirant
Many thanks for the update. I got it working well on a laptop, but in the end I bought a simple TP-Link 150Mbps N Nano USB adapter and it did the job on the QSC Touchmix 16. I couldn't see anything that says the Netgear N150 can only be used on a Windows based computer though, even after reading all of the instructions.
JamesGL
Feb 10, 2017NETGEAR Employee Retired
Hi AntMusic,
You can check the Tech Specs of the device.
