tcj12
Jul 28, 2015Follower
Unable to connect to preferred wireless network
I'm using XP. I have a wnda3100v2 adapter, and I have the NetGear 'Genie' software installed. When I reboot my pc or power it on, the wifi connects all the time. When I'm done, I always put the pc...
JamesGL
Aug 14, 2015NETGEAR Employee Retired
Hi tcj12,
Sometimes wireless adapters drop connection when the WinOS computer/laptop wakes up from sleep mode (hibernation).
Here are some steps on how to prevent Windows OS from putting the USB device to sleep.
- Right-click My Computer and select Properties (or open Control Panel System).
- Click the Hardware tab, and then click the Device Manager button.
- Expand Universal Serial Bus controllers.
- Double-click USB Root Hub (or right-click it and select Properties).
- Click the Power Management tab.
- Uncheck the Allow the computer to turn off this device to save power check box.
- Click OK to exit USB Root Hub Properties.
- Click the red cross to close the Device Manager.
- Click OK to close System Properties.
http://kb.netgear.com/app/answers/detail/a_id/20940/~/fix-wake-up-issues-for-usb-wireless-adapters
JamesGL
Community Team
