isbyrne
Sep 27, 2016Aspirant
Unable to uninstall A6210 software
Hi, Some time ago I had problems getting A6210 software to recognise my adapter and in the process of messing around I have installed two versions of the driver software I now have 1.0.0.32 and 1...
VE6CGX
Sep 30, 2016Master
If you only installed free standing driver, find the folder where the driver is, delete it. You can choose which driver to use from
device manager.
- isbyrneSep 30, 2016Aspirant
Hi,
I have now managed to uninstall driver 1.0.034 and have successfully installed the latest Windows 10 driver 1.0.0.35.
I managed after some fiddling to reinstall 1.0.0.34 again and then uninstall it properly, it then accepted the new driver without a problem. It was strange that there was no netgear folder to manually delete on C drive.
Thanks for your assistance,
Iain
