dadathome
Sep 11, 2015Aspirant
Unable to uninstall WNA3100M on Windows Vista
I have contacted Netgear support but they are unable to help me because my product is more than 3 months old so I'm hoping someone here can help. I recently started having an issue with a message...
dadathome
Sep 12, 2015Aspirant
Hi JamesGL.
Thank you for the welcome and for trying to help me out.
I hadn't tried this but I have now. It uninstalled ok in Device Manager but when I went to Programs in Control Panel the program was still listed and clicking to uninstall is still ineffective, I just keep geting the box with the red cross and it won't uninstall.
Can you suggest anything else I might try please?
Thanks very much.
dadathome
JamesGL
Sep 14, 2015NETGEAR Employee Retired
Is this the only program that you cannot uninstall under control panel?
JamesGL
Community Team
- dadathomeSep 24, 2015Aspirant
Hi James.
I have managed to uninstall two or three other programs using the control panel - Netgear is still the only one coming up with a red cross.
Thanks
David
- JamesGLSep 29, 2015NETGEAR Employee Retired
Hi dadathome,
Can you remove the folder of NETGEAR under the program files? Check if it will be uninstalled.
Regards,JamesGL
Community Team- dadathomeOct 04, 2015Aspirant
Hi. I've now tried that and it just keeps coming up with 'Try again' - not letting me delete from the file folder.
Thanks James.
