Supamarioana
Dec 08, 2017Aspirant
unexpected network error with WNA1100 wlan USB adapter
Hello there, I got the following problem and I hope somebody here can help me out: I receive an 0x8007003B (unexpected network error) whenever I try to transfer several folders containing rather ...
JamesGL
Dec 13, 2017Master
Hi Supamarioana,
Try to uninstall and reinstall the driver of WNA1100.
Supamarioana
Dec 14, 2017Aspirant
Hello JamesGL,
I reinstalled the "GENIE" software including the driver, but no change.
As I described in my opening post, I also installed the adapter on my notebook last week for the first time ever and it showed the same symptoms. But there is no problem when I use the notebook's internal WLAN. So I don't think there is a general problem with WLAN connections.
- JamesGLJan 02, 2018Master
Hi Supamarioana,
Have you tried the standalone version of the driver?
- SupamarioanaMar 09, 2018Aspirant
Hello JamesGL,
Please excuse my late answer. I tested just installing the driver without the GENIE software. And I have the impression that it takes longer for the the error to occur but it is there nonetheless: I copied a 500 MB file and with the GENIE software installed, the error would happen at about 5%. No it happened at 95% but the file is still not copied successfully.
