crikket
Apr 26, 2018Aspirant
unicode error: sftwre install fails
CPU: Dell laptop, Celeron 1.4 GHz, 8 GB RAM; Windows 8.1 64-bit
Smart screen and AV disabled during install
Error message at end of AC1900 software install process:
"Setup launcher unicode has stopped working"
Can this be fixed or should I return the item to Amazon? Thanks
What software are you using? CD? Download?
There is software and a manual for the A7000 somewhere at the end of this link:
>> Click here >> A7000 | Product | Support | NETGEAR << Click here <<
- crikketAspirantNetgear download
Looks like a Windows error.
Try a second download. Or see if Windows will install the drivers from its own set.
That may not be that easy with Windows 8.1, one of the worst versions of Windows to have come out of Microsoft. Windows 10 is streets ahead on that front, with none of the alleged interface benefits of Windows 7. Maybe that is why your installation fails.
